Thermal Paste Review
rapidman17
Ok, this review is on some standard, ubranded thermal paste that Jim asked me to do a review on. Basically, as this is my first review, I am looking for crticism and suggestions for improvement so that I can perfect my reviewing style. I know it is a boring item but all feeback is greatly appreciated. One thing I noted already is that the graphs are quite tacky and there is a touch of noise in the first photo; these things are already being worked upon.
Thanks in advance,
rapidman17
Thermal paste, or more technically, ‘Thermal Interface Material’ (TIM), has historically been one of the more overlooked aspects of system building. It is only recently, due to the rises in CPU speeds, and therefore huge increases in heat generated, that the importance of this viscous substance has been recognised. Thermal paste aims to solve a problem found only on a microscopic level; to the naked eye, the contact between the mirror-finished heatsink and the smooth surface of a processor may seem even, but in reality, looks something more like this:
The gaps you see are pockets of air which, due to its nature as a thermal insulator, can lead to very poor heat conductivity causing a rise in core temperature. To the overclocker, even small rises in temperature will reduce the maximum clock speed, so this unevenness needs to be eliminated. The paste therefore is a thermal conductor -at least 30 times more efficient than air- which tries to replace these gaps and ensure maximum heat conduction, resulting in lower temperatures and greater longevity of the processor.
Thermal paste has evolved rapidly in recent years, and the choice available to the enthusiast has increased dramatically over the last few years as companies try and claim a stake of this growing specialist market. From the well known names including OCZ and Coolermaster, to specialists such as Arctic Cooling and Shin-Etsu, they all offer a variety of thermal pastes that claim to offer the ultimate cooling performance.
However, today I will be reviewing an unbranded thermal paste that does not assert this title, rather has been designed to ‘get the job done’ by providing adequate cooling for the average PC. It is this TIM that you will find in the millions of computers shipped every year; cheap and cheerful it has been used for the past decades by system builders who aren’t concerned with minimum possible temperatures and just need to make sure something is filling those gaps.
Anyhow, let’s take a closer look at today’s sample grease…
The Product
The paste does not come in any meaningful packaging apart from a see-through plastic housing. As a result there is no information or details about the paste, possibly because the manufacturers assume system builders do not require such pleasantries, and also to cut production costs.
Housed in a standard plastic syringe, the TIM itself is white in colour indicating that it is ceramic based and suspended in a gelatinous silicone compound. I’m sure no-one wants me to detail the mechanisms of a syringe; clearly it makes application of the grease easier and fairly controllable.
Applied on the processor we see it has a fairly thick consistency and after 48 hours has held together well. However, it is less viscous than any metal based paste so there shouldn’t be any problems of it drying out. Removal of the stuff should also be easy in the event you need to reapply; some isopropyl alcohol (rubbing alcohol) or ArctiClean will do nicely.
Normally I would list the specification of the product as provided by the manufacturer, but unfortunately this particular thermal paste is unbranded so is unavailable. However, as manufacturers tend to stick to similar specifications for this kind of product , I thought it would be useful to provide a description from one large manufacturer of ceramic based paste:
Specifications
Thermal Conductivity: 1.729 W/m-K
ThermalImpedance:0.125C/W
Specific Gravity: 2.3
Evaporation: 0.001
Bleed: 0.05
Dielectric Constant: 5.1A
Operation Temp: -30 ~ 180C
Storage Temp: -50 ~ 240C
http://www.spirecoolers.com/
Note: these should not be taken as the correct specifications for this particular thermal paste, rather as a guidance of its probable properties.
Before we see how the paste performs, let’s take a quick look at the test system and testing methodology….
Testing
The testbed for this review comprises of the following:
Intel Pentium D 945 @ 3.40ghz (standard clock settings)
Intel reference HSF
Foxconn 662 7MB Motherboard
2GB PC2-6400 DDR2 RAM @ 5-5-15-15 1.8V
Nvidia GeForce 8400 GS
Seagate 7200RPM HDD
Windows XP (Build 2600) Service Pack 3
Having fairly low spec components and a rather toasty CPU, combined with the reference heatsink, should allow maximum stress on the thermal paste.
Measuring the temperature will be done using Speedfan 4.38. This is because it allows us to calibrate the temperature sensors to a lesser margin of error, and also provides Tcase (Thermal Diode located within the CPU die between the Cores) and Tjunction (Digital Thermal Sensors located within each Core) temperature readings. As a result we should find the data gives a more accurate view of how well the paste performs.
In terms of application of the paste on the processor, I will be opting for the ‘blob-in-the-middle’ technique seen above. It is the generally more preferred method as it reduces the risk of using too much paste.
Spreading the paste yourself (above) can also result in an uneven finish. It is easier to allow the pressure of the heatsink to disperse the thermal paste as it will naturally fill the gaps of air, thus resulting in a more even contact.
To give a comparison of the performance of this paste, I will be testing it against OCZ Freeze which is a favourite among many enthusiasts. Each sample will be applied 3 times and averaged to give a reliable result. Idle temperatures will be taken after thirty minutes of the paste being applied, and load temperatures after fifteen minutes of torture tests using 2 instances of Prime95 25.9 for the 2 cores. Ambient temperature during testing was averaged at 22.8 °C.
Right, onto the results then…
Results
Observations
At stock settings we see that the ceramic based paste does a good enough job keeping up with the OCZ Freeze when the computer is at idle. However, at load we begin to see significant differences; it is ‘out cooled’ by 5.3 °C at load and this is only on stock settings. However, at 60.5°C it is still well within Intel guideline temperatures, so does not present much of a problem.
Overclocking to 4Ghz stable was a simple enough affair, but this is where the ceramic based grease really struggled. Hitting the 70°C mark is moving into dangerous territory in my opinion and at 67.3°C during load, I was waiting for my alarms to go blaring and the PC to shut down. By comparison, the OCZ Freeze did a good job keeping those temps down, a massive 6°C less than the ceramic based compound
Overall it is very hard to criticise this ceramic based paste as it does exactly what it was designed for. At standard clock settings it does perfectly well keeping core temps within guideline limits. Cheap and easy to apply, it is good enough for users with average PC’s who aren’t concerned with the highest clocks and lowest possible temperatures. Obviously, enthusiasts who are in fact looking to get the best performance from their setups will not be wanting to use this paste, instead should be opting for the specialist products from the likes of OCZ and Shin-Etsu.
Ceramic based thermal compound (also known as silicon based), like the one used today, is available for around £1-2 from any online retailer or local hardware shop. This amounts to fantastic value for money when compared to AS5 for example which retails around the £6.50 mark, thus making it ideal for the home user or system builder.
The Good
Cheap
Easy to apply & remove
The Mediocre
Packaging is almost non-existent
No instructions for use
The Bad
Not suitable if overclocking
Good review.
It's never easy writing anything, let alone a full review of an item so uninspiring as generic TIM. However, you managed to compose the review in such a way as to keep it interesting to the reader (as interesting as generic TIM can be). I would like to have seen the effects of spread vs blob methods.
As said the graphs could do with something a little more pro but thats something that can be worked on.
name='w3bbo' said:
Good review.
Cheers, thts a good point...i'll make sure to go into more detail in certain areas if need be.
Great review, nice work :)
I'm far from being a tree hugger ( Site manager in the heavy construction industry ) but packaging being somewhat "non-existant" is not only a way to reduce production / distribution costs but is also beneficial to the enviroment.
Save the dolphins ... hug a tree :p
*Looks at overclocked pc folding* :(
It's a good job imo.
Hard one too, but it's a good test of some1's write-up skills when some1 get's u to study something that's, to a greater extent, not very exciting.
However, I read it and the point was made about the product. Info given where it could be found, qualifiers given and the test basis defined. Even if u haven't got too much information about the subject, running off at a parallel with a comparison is a good idea - and u qualified it as I said.
The photo's were 'good enough' imo, I'm the last person that will complain about photography, but u'll notice urself being self-critical and make improvements.
Similarly with the graphs, u had to make one, u got a tool onboard already in the shape of Office, and it does-the-job - it aint too pretty, but u'll see how even OC3D's graphs have changed over time.
Loving the example of cpu & cooler surfaces :) (personally tho I would have scoured the net for an electron microscrope pic to really shove it in people's faces as to how bad the surfaces are) can't mock the example u used tho, again it did the job.
Good stuff.
Thanks for the comment, you points are well appreciated :)
I did have a look for a pic showing the uneven contact surface but there was nothing to be found.....
I mean that's using google images, and tbh I don't know if u need to have rights to use material from other sites like that.
It was a quick search for just "microscope metal".
:D
(god I can be irritating at times)
No No, all criticism and feedback is helpful criticism and feedback imo....
It seems that my search terms werent what they should have been.. i was going on quite a dif. tangent.... thanks though
You made an article about a standard tube of goop a very interesting read. Very very well done indeed! :)
Im glad he sent out something really boring as it really tests the writer, its definatelly something I would not want to do. The revie read well but there was a few things that could do with tweaking because of repeated word use in a paragraph or just bad choice of words.
"Thermal paste has evolved rapidly in recent years, and the choice available to the enthusiast has increased dramatically over the last few years as companies try and claim a stake of this growing specialist market."
Your choices for thermal paste have not only increased in recent years, but the quality and development that goes into the product has rocketed as companies all fight to claim a stake of this growing specialist market
"Removal of the stuff should also be easy in the event you need to reapply; some isopropyl alcohol (rubbing alcohol) or ArctiClean will do nicely"
This bit just didnt read nice and maybe 'TIM' or 'paste' should have been used instead.
Normally when I get asked to read through stuff I scan it then read it front to back, if its my own Ill make a brew, take 30mins off then reread it and see if I can make it any better.
Definately a good review though matey, kudos
Ahh yes, points understood and taken onboard ;). I guesss 'stuff' is too informal; wont be using that again.
Also i see my mistake in the top sentence: should have spotted my repetition of 'last few years.' The rewritten sentence looks good and I shall def be proof-reading even more.
Thanks a lot man, am grateful for your taking some time to help me out...
rapidman17
Like I said dude have a break before proofing it so you read with fresh eyes.
Im no master when it comes to this stuff tbh, but as long as you/and me are willing to take advice then it shows your willing to learn.
Ill gladly take advice from you when my reviews are due ;)
