the timing
You referring to the memory timings that are listed on the Memory Box? Like the standard 9-9-9-24 for a 1600mhz set?
If so then in the motherboard's BIOS just go into the memory settings and put in the settings that your memory is rated for. Or if you see an option for Intel XMP then just enable that and it will do it all for you.
https://www.youtube.com/watch?v=w4sx-GuY3CA
This should help as well
That is helpful.
