So you’ve just bought a brand-spanking new 64-bit processor from AMD huh? To you my fellow PC user, I say; congratulations and of course, enjoy. We all know just how fast an AMD 64 is straight out of the box, it’s fast enough to chew through just about anything you throw at it, literally speaking. So why on earth would you need, or want, more processing speed from this already fast CPU? Well you might already know the answer to that, maybe you just want something more for nothing? For others however, it’s an addiction. Admit it, you are an overclocking addict. You can’t bare the thought of having any piece of hardware in your rig running at “stock” speed. The sound of it is almost offensive to your ears. Or perhaps you just love looking at bigger numbers; you love the feeling of knowing that your CPU is running 200 MHz faster then its original speed – and you grin deviously when you get that extra performance boost. You know the feeling, most of us do. Excuse the borrowed pics, but you'll get the idea and these pics will not be the same as your bios screen
Overclocking an AMD 64 is relatively simple. Just up the FSB and voltage and hope for the best, right? Wrong. While the main idea is to get that FSB nice and high, there are many other adjustments you must make in order to prevent your pretty CPU from turning into a blob of melted silicon. Before you even begin to dive into that blue-BIOS-of-hell, you must first understand some key points.
Note #HTT or Hyper-Transport Technology Is often mentioned in the BIOS as LTD speed.
It should have a multiplier setting next to the name, ranging from 1x to 5x. This multiplier relates to your FSB. So for example, 5 x 200 MHz FSB equals 1000mhz, still with me? Then that number is doubled to effectively give you the overall Hyper-Transport Speed of 2000 MHz. You should know that HTT speed is not the CPU Clock speed; it is simply a technology that deals with the memory controller featured on AMD 64’s that involves the amount of bandwidth available. However, you must note that having a slightly lower HTT speed will most likely not have any impact on gaming performance. So a 3x or 4x multiplier is just fine. The main idea is that you stay under the maximum HTT speed supported for your Motherboard’s chipset. Which brings me to my next point…
Command your RAM
Memory Command Rates can be awfully confusing at times. You should find an option somewhere in that BIOS of yours that mentions “Command Rate” somewhere. When you do, there will be two options; 1T and 2T.
Doesn’t sound complicated, but this can play quite a significant part in running a high FSB. The most important thing to remember is, a 1T command rate is much faster then the 2T, but (there’s always a but isn’t there?) in most occasions you will be able to push the speed of the RAM further with 2T. Running a 2T command rate will only ever be faster then 1T when the actual memory speed is much higher. For example, 1T @ 210 MHz is almost equivalent to 2T @ 240 MHz.
It is generally considered that if you are using 2 sticks of RAM with your A64, you should run the 2T command rate. However, A64’s can be found with different stepping revisions, which I won't go into at the moment as I shall confuse the hell out of you.
Tweaking Time
Last but not least, voltages and Latencies. What’s Latencies you ask? Excuse me while I gouge out my eyeballs before I answer that, but long story short: it involves how fast the RAM responds to commands. For a more in-depth explanation, Google is indeed your friend. So, obviously the lower the Latency times the faster the RAM should perform. Once again, another ‘but’, this time it’s to do with overclocking, what a coincidence eh? Most RAM will be able to clock higher when the latencies are more “relaxed”, as in slightly slower, which allows for more oc’ing headroom to stretch its legs.
Now voltages can be dangerous if used incorrectly, after all, the last thing you want is to end up with a fried chip. Increase the voltages, on either, up in tiny increments, only if you absolutely have to. You’ll know when you need more voltage if you 1) Are experienced or 2) Being told by an experienced person.
So there you have it, all the basic fundamentals you need to understand when you are playing, sorry “tweaking cautiously” around with your AMD 64 CPU. Remember, overclocking does require extreme patience, and it helps to know exactly where that CMOS battery, or jumper, is located on your motherboard. In case anything goes horribly wrong, or you simply are unable to even boot the computer, consult your motherboard manual to find out where the CMOS battery is. All you have to do is short the battery, wait a minute or so, and your default BIOS settings will be returned, how convenient.
Getting Started
When you first begin to raise that FSB, in 5MHZ increments at a time, keep in mind that if your RAM divider or ratio is set to 1:1, then your RAM will also increase its speed. You will also get better performance with running the FSB and RAM in sync, 1:1 ratio, so try to find your RAM’s limit before you change the divider to something like 5:4. Also remember what your chipset’s maximum HTT speed is in MHz , then once you have gone above it, you should lower the HTT multiplier.
If your overclock is successful and you can boot into Windows, first run a program such as Prime 95, or any other CPU intensive benchmark, to see if you still maintain adequate stability. Then, once you’ve found the highest, stable clock, try running SuperPI . This will give you a sign as to whether all your hard work payed off.
PV
Command your RAM
Tweaking Time
Getting Started
PV
