3770k with a z77 board. Overclock it. And I'm sure you can get some gear at reduced prices since it's technically outdated.I am still running my Phenom x6 1090t. I am looking to upgrade from it to intel. The most I will be running sata-wise is 2 ssd's and 2 hdd's.
If you're buying now - I'd be buying the latest tech.
Compare the price differences. I worked it out for my friend the other day and getting Haswell over Ivy only came to about £30 more expensive (depending on the board).
Nothing at all wrong with Ivy, but it'll lose its appeal more when you come to resell it a year or so (or whenever) down the line, and it wouldn't even be last generation.
Tom would get an engineering sample 4770k and the best motherboard he could. Something high end Asus or Gigabyte...What would Tom do?
im guessing u r an amd man
