R RadeonHDx New member Feb 22, 2013 #1 So my simple question... What is the best reference PCB 7970? Also which is the cheapest with a reference PCB? Thanks
S SeekaX New member Feb 22, 2013 #2 they are all the same. that's why they are called reference cards.
WillSK Active member Feb 22, 2013 #3 SeekaX said: they are all the same. that's why they are called reference cards. Click to expand... Yeah this ^ . The only possible differentiation might be Warranty times etc.
R RadeonHDx New member Feb 23, 2013 #4 Ok, I probably should have researched stuff like that first. Do any of you know the cheapest card?
E Etlar New member Feb 23, 2013 #5 Why not seek it out your self mate, i dont know the shop in GB. But normal you just set the thing on shop website just to show 7970 only
J jamesriley94 New member Feb 23, 2013 #7 RadeonHDx said: Ok, I probably should have researched stuff like that first. Do any of you know the cheapest card? Click to expand... Varies by retailer. In the UK no manufacturers offer warranty on AMD cards if you take off the cooler - which I assume you will be doing. The cheapest ones seem to be around the £300 mark.
R RadeonHDx New member Feb 23, 2013 #8 jamesriley94 said: In the UK no manufacturers offer warranty on AMD cards if you take off the cooler - which I assume you will be doing. Click to expand... Yep, you're right thanks as always
