Temps wrong?
hardw1re
I dont get it, the Evap head is reading -61 degree's Celcius. Yet the system is telling me my CPU is at a constant 40 degree's Celcius with/without load?!
Most mobo's don't read sudzero temps correctly what mobo is it and also are you sure you have good contact???
Yeah Fatty, the back plate is extremely cold! I've just fitted the Neo2 Platinum. its at a constant 40 no matter how much load goes on it! :|
its just crazy thoguht how when i put my hand on the back plate (the one behind the motherboard :P) its extremely cold, as if all the heat has been drawn out by the cooling unit.
yay the bios on this new board is lovely... how am i suppose to overclock this thing :S i dont even know what the actual CPU temp is?! its at 40... bios 40, windows 40, 100% load its friggin 40! ?? this is annoying :(
common prob with Neo2 I'm afraid , could always try and fit a temp probe near the cpu but then again not gonna give correct temps , I hear that the new bios has sorted the temp on the MSi havent tried myself tho
Wow this is even more stupid! i have just updated the bios to 1.18 (i think) - guess what temperature MBM is telling me for CPU. -100 degree's C?! the bios crashed trying to read it too :| any other ideas??
ignore it : general rule when ure using subzero tempritures if the overclock is good dont worry when i had my max 3 the temps were all over the place .mother board probes just arnt designed to read the tempritures your exposing them to .
yeah but my old board you see... it just sat at 0 if it was below 0. + does anyone know how to overclock on this board? what should i do to overclock sensibly? cause i still need some guidance with voltage ratings and stuff
