temps too cold? -70c
tkd
hey guys, my prommie his hitting minus 70c with the head disconnected and on an xp3200 at idle, stock voltage/oc etc, is doing around -63c, its not a GT unit just a mach 2 with the nl11fn compressor, 240v australian version
does this seem a little too cold guys?
fan speed is on normal aswell,.
If the board and CPU work fine theres no such thing as "too cold" :D:D
Seriously though-its just the evap temp reading being inaccurate. Mach and Vapochill are infamous for it
yes, my machII used to read low; but not -70'C!!
You could check the mobo sensor and see what temp that reads it at. However, the best way to find an accurate reading is to get a temp probe down there and see what it's really doing! :)
