Temperature monitoring software
kleentribble78
hi,
I've recently built an extra PC with some fairly old components. The BIOS reports my cpu is idling at 14 degrees but it doesn't have a reading for the mobo. It is a Biostar motherboard with an micro atx form factor and has a athlon x2 3800+.
I dont know how accurate this particular motherboards temp sensor is, but can anyone recommend me some freeware temp monitoring software that runs in windows? if it can also monitor fan rpms then thats a bonus.
thanks
hi
I'm using a Win7 sidebar tool for that: IntelCoreSeries by blog.orbmu2k.de.
Lists cores, core load, core temp in F or C. It's using a driver called "WinRing0 Driver" that comes with it and needs to be installed for the sidebard gadget to work properly. fan speeds cannot be monitored.
further I'm using a similar sidebar gadet to monitor my GPU: GPU Observer (also downloadable at blog.orbmu2k.de) it can display fan speeds, temps, voltage, load, clocks if supported by the card (works for AMD and nVidia).
have fun
BaMb1N0
hi
have fun
BaMb1N0
I use these as well.
I do get CPU fan speed monitoring on the CPU gadget though...
oh darn it that looks good, but I'm running xp pro 32bit on this particular computer. Sorry i should have been more exact when i first posted.
