Taking a Mach 2 apart
GoLLuM4444
OK I need to take all of my Mach 2s apart and swap them around (due to modded chassis). How do you unmount the compressor from the chassis? Is it just a simple case of pulling the clippy things at the top off? I've tried quite hard to do this but with no luck, any tips?
You got it right - just pull the clips out (using pliers) and then push the gold plugs down. They should pop out nicely :)
