B BAcon New member Aug 10, 2005 #3 they are good, just be sure to get the rev 2, rev1 had a problem that caused them to fail, avoid if its a rev1 if its rev 2, its essentially identical to the AQX
O OV3RCLOCK3R Banned Aug 10, 2005 #4 Found out that its a rev.1. Going to leave it then. How does a 80.2 rad perform capared to a Black ice Extreme?
B BAcon New member Aug 10, 2005 #5 OV3RCLOCK3R said: Found out that its a rev.1. Going to leave it then. How does a 80.2 rad perform capared to a Black ice Extreme? Click to expand... only go for rads that can take 120mm fans matey in order of efficiency (how good they are) *thermochil 120.3 / weapon modded dual heatercore *dual heatercore *thermochill 120.2 / pa160 (assuming the air flow isnt restricted in anyway, otherwise the pa160 is below the 120.2) *single heatercore *thermochil 120.1
