The 'cards' do not really have much graphical prowess and are only capable of rendering 2D @ up to 1600x1200 with a 24-bit color depth but should be extremely useful to easily and cheaply add Multi Monitors to a computer system.
They will be available in DVI and VGA flavours
Swordfish 9 Headed System anyone ?
|Source :: FUDZILLA|
The VGA 2626 utilizes DisplayLinks Virtual Graphics software which has two functions. The first one is to compress and send the video data through the USB 2.0 bus while the second function remembers each adapters screen configuration data. The software can easily expand your desktop to the adapters (or clone it), and if the user desires this device can easily be used as a primary graphic device.
|Source :: FUDZILLA|
