Suggestion for a P67 MOBO
COLDHELL
Hello again Guys, thks in advance for the time.
so yes, I'm looking for suggestions, comments and deterrents points of views Im looking for a MOBO Between the 150.00 and 200.0 the reason why is a change computer often so it hurt when you spend a Lot of money in a MOBO+CPU and then, another technology is coming in the corner, this are my choice, I'm open to any recommendation
ASUS P8P67 LE (REV 3.0) ATX Intel Motherboard
ASUS P8P67 (REV 3.0) ATX Intel Motherboard ASUS P8P67 (REV 3.0) ATX Intel Motherboard
GIGABYTE GA-P67A-UD3P-B3 ATX Intel Motherboard GIGABYTE GA-P67A-UD3P-B3 ATX Intel Motherboard
MSI P67A-GD65 (B3) ATX Intel Motherboard B3 Ready; HardOCP.com Gold Award Winner MSI P67A-GD65 (B3) ATX Intel Motherboard
ASUS SABERTOOTH P67 (REV 3.0) ATX Intel Motherboard ASUS SABERTOOTH P67 (REV 3.0) ATX Intel Motherboard
NEWEGG COMPARISON
I also atach a PDF file with more information.
Gigabyte P67A UD4 or the Asus P8P67 PRO are the best midrange P67 motherboards, the Sabretooth is ok but it's basically the PRO with TUFF armor which is more of a gimmick than anything and with a different colour scheme. The MSI I don't know much about but they are ok from what I have read. Other than those motherboards the next best, but expensive are the asus Maximus, MSI BBM and the Gigabyte UD7. Personally if I had the monie I would go for the UD7, maybe the MSI BBM but if it's a mid range board most likely the UD4.
Thks for your response SieB I really like the GIGABYTE P67A but it doesn't come with the new UEFI bios, I don't know if its a big deal..
It doesn't affect anything performance wise, UEFI is basically just a normal BIOS with a flashy GUI which you can use the mouse on instead of using the keyboard. If you would rather have a UEFI BIOS I would go with Asus but if you aren't too bothered about it the UD4 is a good board to get.
The only real upgrade you get with a UEFI BIOS is the possiblity to boot from a larger than 2TB drive/array apperently.
but with SSDs who really needs it
