Stupid question
Mr. Smith
So I bought this case aaaages ago...
I've decided to run with it as I have a pa120.3/pelt etc - need the real estate.
It was second hand and a lil beaten up.
I was just cutting the holes for the rad and noticed the mobo tray, it has square holes.
How do i mount the mobo to the tray if there are these big (ok so they are prob 3mm squares but still) square holes?
It didn't come with any 'bag of bits' so...???
I'd supply a piccar but camera is dead atm...
sounds like the type of mobo tray that uses little removable mounts.
they are "sprung" in that you need to compress them slightly to fit them & they then push against the sides of the hole plus have little tabs to prevent going right through. e.g. beantech igloos have them.
have you tried places like maplin and rs. Them kind of mounts are common with with rack mountable music kit.
Cheers mate, they look just the job!
Rast - there us no bag of bits! Doh!
Cheers nuzio - will look in maplins for them
thats the ones mate
repped :)
Eek, I got 5 (2 like the above and 3 sexier ones :p ??) plus 5 plastic raisers that might make up the difference, they "pop" in the case holes and press through the mobo holes with `sticky out tabs` that hold it in place. Kinda things u use when, like XMS, u change-out mobos alot and don`t like unscrewing em ;)
Wanna give em a shot ?
I can stick em in a jiffy or something 2morrow.
Sweet! Do you want some mullah? I'll also give you something money can't buy, no not my love, but almost as good - reps lol.
Appreciate that :D
I'll PM you my addy... Now all I need to find is some screws it fit though these delta fans into my rad... (goes to DIY store)
PM me u`r addy and I`ll post em 2morrow.
Normal mobo screws fit in em.
Well over 500 post, over 40 reps and a green newsy guy ? How can I possibly charge u ? :p
