Being a girl and all I have nails and I accidentally ummm flicked the K and , buttons off. Not only that the squishy things came off too. I am too lazy to fix it.....
Pretty sure that laptop keys can just be replaced with a bit of force. If it looks like it could clip back in, put the rubber damper back on and just press the key down on it untill it pops.
Yeah I know I'm just too lazy the rubber thingo wont stick back on so I gotta get some glue or something -.- which requires effort. I usually flick the C button off but I can always put it back on fine....with these two I was a bit more retarded with *sigh*
You could always just get a USB keyboard of some sort and use that instead. I know it defeats the purpose but the keys dont come off as easy. Ive had to fix laptop keys a few times before and one time it was so bad i had to super glue the key on then play with it enough so it would work easily.
Sif cut my nails.... I like my nails hehehe. I would get someone to fix it but I really cbf going to a place to get it fixed. I think I will stick to the glue thing heh.
Like others have said if the plastic thing is there and the rubber is on it should snap right back in. If not, some glue on the right part will work. Will hold it without keeping it down.
Thanks for helping guys..but my laziness is just stopping me from doing anything. LOL I should take a photo of my laptop to show how retarded it looks :S
Do not worry the keybord can be replaced with a bit of force. Just calm doen and try to put the key in its place. If you can not you can ask someone to help you it is pretty easy.
