Stupid buttons
Socks
right, i think ive asked this before, my GF's keyboard on here laptop is only allowing her to press the second selection on that button. Normally she can only press this is she is holding the FN button.
Any ideas on how to turn this feature off, as she cannot press full stop , ROFL!!
Cheers guys
depends on the model etc, disabling the Fn lock is usually a key combination like the Fn button and num lock/scoll lock or F12 and num lock or something similar
as above, we need to know the make/model. From what i remember it's usually the num lock key. If it comes on after every restart have a check in the bios and disable it.
Try holding shift or pressing it 5 times.
It enables/disables a program called 'Sticky Keys' which automatically picks the second selection on each key you press.
Either that or I read your question wrong.
:D
