strange glitch
garih
hi, i have been having some odd things happening, i just tried to launch a game and this happened, it has happened a couple of times before, no idea why, i unplugged the displayport cable to the dell monitor and the same image moved over to the other screen, plugged it back inb and it moved back, last time this happened was just watching a game vid on steam store...
all drivers etc are up to date, last time this happened the gpu was not oc'd, this time it is. all temps are in good order etc,
Have you tried using the Beta release as well as rolling back?
Might be an idea to Driver Sweeper the AMD drivers and re-install fresh.
I'm no expert, but to me that looks like a refresh-rate desync?
Or maybe the connector is lose, have you checked that? Such strange errors are often result of problems that are so obvious you overlook them ;) (as far as replugging it goes, have you plugged it in into another Port yet)
Btw. disregard my tips in favour of tips from other users here, I usually don't run into PC trouble, so I have not much experience with troubleshooting ;)
I'm not at home atm. I will try the driver wipe and beta install When iI'm home later.
I have swapped the displayport socket in use already
Are you using a display port to DVI/HDMI adapter? Or is it a displayport monitor?
I'm pretty sure this is connector related, and not driver, since your other screen is running fine.
Same thing happens to a friend of mine's - on his eyefinity set up, the one screen going through display port does very similar things to this.
im using a dell u2412m screen, with a mini displayport to displayport cable, i dont think it is connector related as when i unplug the displayport cable the glitched image moves to the other screen...
