Rastalovich
I`d never figure that an OS would frig a machine`s hardware.
Case 1. We get an Acer laptop in the stores today, had Visa on it and user wants a standard XP put on it.
It`s not a special laptop, infact it`s 2 models down on the Acer travelmate I got.
By all means - the harddrive is coming up *bad*. Attempt a vanilla XP build and it BSODs just before the writing to harddrive stage. Memory checks out fine. DOS tools won`t detect it, well one did but won`t do anything with it.
Switched out the drive for 2 others know to be ok and the same thing happens.
Search the `net and there`s many a problem exactly the same just for the Acers. Stop 0x0000007e pci.sys probs.
Gonna attempt putting Vista back on it - if that works then that`s pretty darn shocking.
My personal belief is that as soon as the bios is flashed and cleared, everthing will probably be ok.
Case 2. Come home to receive an email from Tx about another user with the same thing. Only this is a Compaq.
What it looks like, for the want of a reasonable answer, is that sticking Visa on these laptops is playing with the bios - and if u attempt to re-install something else it effs it.
Can`t be all laptops, maybe ones it feels the need to *tweak* or something - I dunno, guess work.
Either way, what`s bothering me atm is I have Visa Ultimate on my Acer.... and I`m thinking of ditching it....
