S stocky New member Jul 1, 2005 #1 I have managed to get a big blob of seal string stuck to my carpet. My computer chair has been rolling over it and it is properly stuck to the carpet! Is there a known way to get it off, without using a blow torch?
P Phil Stanbridge New member Jul 1, 2005 #2 If its still "tacky" you can use another ball of sting to pick off the majority - then you can use vanish or some equivalent.
F fatty New member Jul 1, 2005 #3 you need the spray they use to get chewing gum off loool its like an ice type spray loooool
S stocky New member Jul 2, 2005 #4 Hmmm, it's quite stuck. i just tried to suck it off with the Dyson - no luck Heres I piccy of it:
R R Nibleck New member Jul 2, 2005 #6 stick the head of ye prommie on it and freeze it off failing that get down to your local plumbers merchant and get some pipe freezing spray.
M Master_G New member Jul 3, 2005 #9 name='Faaip De Oiad' said: Paint it green. No one will know. mwahaha Click to expand... I like your thinking G
F Firelord New member Jul 3, 2005 #10 Exactly as the others said freeze the bugger Only way to chewing gum off and its a similar tackiness!
S stocky New member Jul 3, 2005 #11 Good idea sticking the head of the prommy on it! I'll wait to get some freeze spray... ...The landlord wouldn't be too pleased if he saw it!
S stocky New member Jul 3, 2005 #12 Saying that, will seal string freeze?! Hasn't it got a huge operating temperature range, as it is used around the CPU socket/ head of phase change & Liquid Nitrogen...
R R Nibleck New member Jul 3, 2005 #13 ermmm good thinking, i will just go and give it a try (edit) if you give it enough spray it does go hard and is easily picked apart, the stuff i have in the van is rothenberger spray but any should do it.
S stocky New member Jul 3, 2005 #14 Excellent, I'll go get some of that spray sometime during the week! Cheers
