Starting to overclock X 2 4800
clone38
Ok this is how far ive got with my cpu,first time overclocking a cpu so beware :D
Clocked on retail heatsink
DFI Expert Bios 12/07/2005
x 2 4800 12X 225=2.7GHZ
CCBWE 0538RPMW
Western Digital Raptor X 150 GB
BFG 7800 GT
Nec 2510A DVD writer
Seasonic S12 600W.
Cpu startup value startup
Cpu core volts 1.37v
Cpu VID Control Auto
Cpu VID Special control 104:8%
Mushkin 2GB-XP4000 Redline Extreme
3-3-2-8 T 1 timing
Ram volts 2.66v
Smartguardian reads the ATX+ 11.77V
CPU Temp 30c
PWMIC Temp 34c
Chipset Temp 43c
Trying to push this cpu as much as i can on air till i set my mach 2 GT .
Any tips are more than wellcome....
Stock cooler m8 :) ive got a feeling the psu isnt up to the job,but im waiting to see what sort of price the new 750w PCP&C is.
Any ideas on how i can clock this cpu a little more,should i up the core volt and try more FSB? anything above 225 FSB core volt 1.37v the pc will not boot.:?
Not tryed upping the ram volts yet but will give it a go, as for the RAM divider any ideas what setting to use m8?
My absolute max stable with the system I'm currently using (PA160/C-Systems/NV78 and G4 all at 7v virtually silent) is 2.64ghz, so 2.7 for the stock cooler is good.
Try just whacking it on a 166 or 180 divider (this will rule out the memory as the culprit) or reducing the multi to 10 to check its not the ceiling
Hey, looking like a nice setup :)
Few things.. if you could post an A64 tweaker shot you might be able to pick up some timing help.
I'd also drop the multi and run higher memory FSB. Do you know what your Redline craps out at?
Update:
Today`s overclocking results.
Fsb 260 x 11 = 2.8ghz :)
Cpu temp 36c
Core volt 112% = 1.47
LDT/FSB 4X
Ram volts 2.71v
Now that ive put up the core volt should i try 12x multiplyer again and see how it clocks?
Just ran memtest for 4hrs with no errors.
Cheers for the help so far people :)
