Spiderz
Long story short is that, over the next 18 months or so I plan to do a major overhaul of my current computer with a switch over to an mATX build and I'm going to have to buy everything over time due to the overall cost and a job change on the horizon as well.
I am mostly set on what the specs will be with only a few uncertainties which are related to the time frame as some stuff might be following this generation.
Uses: Gaming (BF3/4,batman Arkham Origins sort of stuff) , standard web browsing and office work and some light media work.
Proposed Specs:
Corsair 350D
Gigabyte G1 Sniper M5 or Asus Maximum VI Gene (not sure which of the two) paired with an i5 4670k and a H100i
Corsair AX 760 (is it worth getting the 760i instead for £15?)
GTX 770 or AMD equivalent at time of purchase
Samsung 840 pro 256GB
Current 1TB HDD, optical drive and RAM can be carried over at this time.
My two problems lie with the motherboard choice and what order to start buying everything in as it will have to go in my current setup as well. I'm thinking that the PSU should be the first on the list as I am a bit wary about my current unrated one and after my brother's similarly aged version of this went bang a few months ago I fear mine will follow at the worst possible time. I am happy to sit with the 5770 I have for a bit longer and don't mind turning stuff down just now as I know that I won't be gaming heavily for the next while but I will go back eventually.
TL;DR What is better, Asus Maximum VI Gene or G1 Sniper M5
Where do I start my upgrading first? SSD or PSU
Proposed Specs:
Corsair 350D
