Stacker 830 or Lian li PC 70
Status
Not open for further replies.
robump
Hi i am considering getting a new case, i have at the moment at Lian Li PC 70, but are considering getting a stacker 830.
Please could you advise me on whether the best option would be to keep my lian li, and buy a side window for it or sell it and buy a stacker 830.
Thanks
Rob
Not a huge fan of the stacker 830's looks to be honest mate. Bit sci-fi really.
I would put the money into pimping out the PC70 perhaps? Or save up a bit and have a good shop around, there are some seriously stunning Lili's, Silverstones and MountainMods cases out there
Thanks, im going to be water cooling, so i was thinking i will probebly go out and buy a side pannel for it, still open to suggestions though.
Rob
Ok, i think i will keep my lian li, ill need to wither buy a side window for it, or do a bit of modding:D . Side windows are pretty expensive, kustom pc's price is £44.
Thanks
Rob
Having owned a Stacker 830, I would suggest keeping your Lian Li. The Stacker 830 is a great case, but the LiLi's or some of the Silverstone cases are so much roomier and component friendly.
Edit: Robump has decided to keep the Lian Li - thread closed per request
Status
