SSD to RAM
mdk4ever
Hi,
I want to ask if I purchased an SSD can I use it to increase RAM using "ready boost" or increase speed and store virtual memory on it ?
Thanks
Have you got any more details about your current set up? There are some pretty good deals on Aria at the moment for Mushkin memory...
Hi,
Thanks
Why would you ever do that? If you're getting a small SSD, just put Windows on it and then get some RAM, its cheap. ReadyBoost makes absolutely no difference when you have 4GB or over of RAM. It most certainly won't speed up games much. The only time I ever used it was when I had a spare SD card (4GB) and 2GB RAM in a netbook, and even then I just got 4GB RAM.
