AlienALX
Well-known member
Right. Last year I built a NAS. It was great fun. However, inside it is severely limited for space for storage. However, I won't be breaking it down as it has been great* but I have now found myself in a position with a shed load of SATA SSDs that I can't use.
*OK so running it over a power line is a PITA, as it drops from time to time, this one though will be fed directly into the router via a cable.
Any way, I have 3 250gb SATA SSDs. Two 500gb and three 1tb. Now I would ideally like these in my PCs but one of them it is impossible (the ITX) and the other it's extremely difficult and not worth the mess (new Alderlake upgrade rig).
They won't fit in the NAS, and so I am going to build a second server. This one however will be almost completely passive and buried in the eves of the building (it's really cold in there. Insulated very well, but cold). That way it's totally out of sight and due to being silent I can run it 24/7./
Before I continue I want to say a huge, heartfelt thankyou to NugentS. For sending me his pile of server cards and parts. I haven't had time until today to actually go through them, but yeah these parts are like pieces of gold for what I was planning. So again, thanks dude !
I just went through the SAS cards, and spotted a 16 port 3ware card. That should do on its own (lol) but I do have other cards too. So ports won't be a problem. I haven't ordered the SAS cables yet, but will soon.
The spec of this thing will be the drives listed above. As well as (if it works, I can't even test it because neither of my current rigs will accept a full height card) a 960gb Revodrive X2. This is the 1700/1500 version, so it's really quick.
For the board and CPU? my old Threadripper I used for two months before I got the cash in a windfall for my uber fast PC. I will be using a H100x boggy standard, with two Eloop bionic fans on it.
Because I am using a Bitspower WB mount kit (long story) I need springs. I have them, I just didn't have them with the parts at that time. The AIO looks a little something like this.
It needs paste and the springs added to tension the block down. That takes care of that. The GPU I am using will be the passive 7300GT that NugentS provided. It has a VGA port on, which is what I needed. This will connect into my TV's VGA port so if I need access it's very easy.
Not decided on a RAM solution yet, but I would suppose 32gb would be more than enough.
Case. I want something funny. Am going to go with the sleeper route, and order this "ACME server case". Yeah, no BS, that is actually what its called
I am going to have to cut the absolute crap out of it to give it modern manners. However, it's wonderfully made. Full steel chassis with aluminium handles and bay covers.
I've sorted through all of the ideas. Over the coming weeks I shall be putting them into motion. BTW, if you think it won't hold all of those drives? you may be correct. However, the RAID cards I will not be using have vented PCI brackets on the back with two screw holes. This means I can make acrylic plates that hold 3 2.5" drives on each. That kinda look like a big GPU, only with drives on.
