WYP
News Guru
Is your PC ready to finish the Tomb Raider Trilogy?
Read more about Shadow of the Tomb Raider's PC system requirements.
with a 1060 recomended, you´ll have to play high details and not everything activated. So not realistical this pc recomendations.
A 1060 for recommended is pretty good considering the graphics in this game.
But ... it is really not saying much is it? If anything, it is the marketing department saying that THEY suggest you buy the game if you got that card. And their interest is sales. I think they are OK with you being able to run the game around medium settings....
A better way, would be to list what is needed to run the game at various settings. "Recommended" is really worthless.
General rule of thumb -
Minimum specs - What you need to run the game at THE lowest possible settings at a very low resolution.
Recommended specs - What you need to run the game at default settings at a resolution of around 1080P.
It's not really worthless, It's just a bit vague.
They have to be vague because there's too many variables to guarantee an exact frame rate. Two PCs with the same hardware could run the same game at different frame rates because of the setup.
It's been done before with great success. Really not much of an excuse to not include it. You can say this recommended list should be able to run 1060p60 at High/medium/etc settings. If you have such a degree of difference in the same hardware that it becomes impossible to know how it will run then it's most likely down to optimzation. Yes in some cases it's user end. But if for example it's like PUBG where high end hardware can either run it great or terrible, even on a fresh install, that's definitely Dev end. That's even using UE4 which has many great games that run well.
Now I understand why you said what you said because you indeed are a software developer, however it's not always user error. Now as you know I'm on track to earning my CS degree so my limited knowledge in comparison to you means you are most likely right. However I'm confident enough to believe my statement has merit, not always but definitely exist.
No I just mean I can see why they do it, to save their asses. I've debugged compatiblity issues like this in the past they often tend to be software related due to something else installed. i.e. f.lux can completely destroy a game's frame rate, fraps can often crash drivers, etc. I'm not saying they should do it, I can just see why.
