Spec me a Smartphone
Dicehunter
Resident Newb
So I'm looking to get a cheap smartphone for work, I don't want to spend hundreds but I would like a decent'ish thing not something that will take 5 minutes to react to touch, Or even a tablet with wifi and bluetooth.
Preferably around £100.
That's a fairly tight budget IMO, older high end phones are at the end of their battery and update life and new hundred quid phones are a bit disappointing.
Sony Xperia X seems to be widely available at ~60 pound mark, is flashable with LineageOS 18.1 so you get frequent updates and the budget allows a battery replacement. But someone more knowledgeable than me likely has better and less cumbersome options.
Edit: Scratch the LineageOS 18.1 comment, seems to be experimental at best. Moto G series re decent budget phones, maybe one of those second hand allows for an up-to-date device.
I can donate you an iphone 6 if you pay the postage which is probably £30-40. It's a bit dated but not bad.
I love your face Warchild !
We can discuss it over Discord for details when you're not busy with Elite Dangerous ;)
