SP120s on H100, push or pull? (can't do both)
captainpatje
Hi Forum,
I currently have a H100i with 2 SP120s connected to it (Not the stock SP120L's, but the Quiet editions)
Now for cooler results push is prefered, but for easiest cleaning push is. I would do Push/pull if there wasn't a huge heatsink on my motherboard preventing that from happening.
So, what do you recommend?
Now for cooler results push is preffered, but for easiest cleaning push is.
Hmmmm? Pull is easiest to clean, and to be honest push or pull where cooling is concerned is only makes a tiny difference.
In my opinion you should worry more about ease of cleaning or aesthetics.
You wouldn't need to clean it that regularly if you've got your case nicely dust filtered or have positive pressure
Can't top this post^^^ basically what everyone else would tell you.
/Thread.
