Sound card to gaming ?
Etlar
Need some help here, will like to get away from that onboard soundcard. My old sound card died 3 weeks ago. And now i have the money in the bank, but what to take ?
The thing i will use it on is, gaming "Wow, BF3 and so on" But will also use it to music, and only use headphones whit a mic ..
Best regards
Christian "Etlar" Hesselberg
Any thing with an x-fi is great for gaming if you can source one.
Just whatever you do DON'T buy one of the latest recon3D pieces of tosh.
Same as Tom I will recommend you getting one of the Asus Xonar Series, for example D2X, or even Phoebus, or STX, but it all depends how much you can spend.
Yeah STX is great card, I will be getting one for me in near feature. But Phoebus is similar to STX, I think that they even have the same amps.
They use the majority of the same parts. But the Phoebus is made for gaming, and so adds bass and effects, whilst the STX produces the intended sound perfectly.
The Phoebus is more made for headsets, and so doesn't perform well in things like music and films - in fact, in those it's not great at all.
The STX on the other hand is made for listening to/creating music primarily. So it reproduces the sounds pretty much perfectly - and has also been designed for use with headphones, not headsets like the Phoebus.
You can add effects with the STX to make is more bass heavy, and sound exactly like the Phoebus - but you can't make the Phoebus sound like the STX, making it pretty redundant against it.
If the OP is ONLY using it for gaming with a headset, then he probably wouldn't notice too much difference between the two. But as he's also using it for music with proper headphones too, the STX is always going to be the better option.
This may all be pretty irrelevant however as the OP hasn't given us a budget, and we're talking about the two most expensive cards on the market :lol:
Yeah I agree with that what you said.
So far he didn't gave us to much info to help him, well we will see:)
Sorry my late time here, but was out and running whit the dog ;)
My headset is steelseries 7H, the Black and yellow one. Work lovely in theme whit my build ;)
My old Soundcard was cretive 3D i Got cheep, but will like to jump up alot more. Can use around 200£ on a Soundcard.
Don't waste the money on an STX or Phoebus then.
You said headphones in the OP - you mean headset.
Something like a D2X will be more than enough for you.
You don't need the headphone amp in the STX or Phoebus, and with a headset you won't see much difference between either of those and a D2X, or probably even the standard DX tbh.
If you have the budget, maybe think of getting a proper pair of headphones, then get a good soundcard.
What is a proper pair of headphones in your head mate? :)
And yes i was mening headset in my OP, Sorry on that fail.
A headset has a mic built in, headphones don't.
Headsets are made cheaply, have bass levels way too give a higher 'boom factor' in explosions and stuff in games, and are generally massively overpriced. They also suck in quality in music and films, as they made pretty much just for gaming.
Headphones are made more for music and so produce a sound as accurately as possible to the way the producer made it. So these are far far better in music and films. Also, soundcards normally have software to put headphones into gaming modes with higher bass levels, and in doing this you get far better quality audio in gaming too.
Any headphones are pretty much better than a gaming headset.
Because headsets aren't great in quality, there's absolutely no point in spending £200 on a soundcard.
But, your budget is big enough to get a good soundcard and a decent pair of proper headphones too. So I'd probably recommend doing that.
I can even go up to 400£ if needed, just done my last set up in cable to a hifi geek here in Denmark. So the gold to me is, get the best Sound out of all things. But still have that mic some place, when i need to use it.
Get the Xonar STX and a pair of Beyerdynamic DT770s (80Ohm version)
then you can get any cheap lapel mic or monitor mounted mic. For using VOIP and gaming, you really don't need to get a good quality one as it makes no difference.
I bought mine for £5.
Something like:
http://www.amazon.co.uk/Speedlink-I...WC22/ref=sr_1_1?ie=UTF8&qid=1359127225&sr=8-1
or
http://www.amazon.co.uk/Ex-Pro-Clip...39?s=computers&ie=UTF8&qid=1359127286&sr=1-39
Will be absolutely fine.
I have found the "Beyerdynamic DT770 pro" here in Denmark, but they only use 3.5 mm mini jack, and the STX use 6.3 mm and where do i put my mic in to the STX ?...
No they don't. They use 6.3mm, and the end screws off to give you 3.5mm too.
There's a microphone port on the STX, and you get an adapter (3.5 to 6.3) so you can use that too.
