I like the look of the digital only version better, but the collector in me likes physical games on consoles. It doesn't look like it can be turned on its side, but I hope so. I wonder if Sony got its inspiration from Portal.
Thanks, I actually like the look of that. It'll look great hidden away in a cabinet.
The ONLY reason I would get a PS5 is for the game series called INFAMOUS. All the other PS5 exclusives mean nothing to me whatsoever.
No console should EVER be standing up. Put it how it should be.....Horizontally.
That said....IF they smarten up and make another Infamous game.....I will get the one with the disc drive. All digital only consoles are a stupid idea. The drive adds more value, and will allow for offline play.....whereas the all digital version probably will not work with an internet connection.
SMART people will choose the version WITH the drive.
Where it will most likely overheat and fail. Good choice.
I hope your cabinet is well ventilated.
It's hugeee going from the side by side comparisons, even the Xbox Fridge looks compact besides it.
Wow that thing is massive. Like MATX massive.
I wouldn't even have room for that tbh.
