njallday
Hey all, I'm planning on draining my loop shortly and switching out the tubing due to plasticizer build up. I have a bay res/pump combo (XSPC X2O 750) with a G 1/4" adapter on top and barb fitting with a small piece of hose for filling, and I'm just wondering if it'd be safe to (after removing most of the hardware) tilt the case and draining through the fill port. The other option is to remove the cpu block and loosen a fitting over a bucket. I'd much rather the first option, but I'm just making sure it's safe.
Thanks a lot
Thanks a lot
