IMPORTHUNTER
I have searched around the net and I keep coming up with PC cooling forums so I will give it a shot since you guys know how to do this. Here it goes:
I have a air compressor, this compressor is on my truck. I have tried many ways to air cool this thing, It reaches temps above 300* at times. The whole case is made of aluminum. I painted it black. First let me draw a little diagram of the set-up currently in use:
The idea is to suck the heat out of the case (where the pistons are), compress it, and introduce fresh air and oil to the case.
Now, I have perfected the cooling of the air INSIDE the compressor I think it is the most efficent way to do it and have proved this in a bunch of them I have built. Now the biggest problem is how to remove the heat from the aluminum casing. I think this would make ALOT of diffrence.
I have access to the same stuff on my truck as you do on your computers, a 12Volt source and I can tap into the cooling system on my truck. I am thinking of coiling copper lines around the hottest parts of the compressor and run antifreeze/water through them. What do you guys think the best way is? I dont care how extreme it is.
Thank you!
Thank you!
