Hi everyone,
I am going to be ordering a PC very soon (end of the week hopefully) and need some help making sure I picked out the right parts, I have gone through the list and everything looks compatible to me and fine, just wanted a second pair of eyes to double check and also if any of you have any suggestions as well for the build. The rig will mainly be used for gaming on a 1920 x 1080 monitor @ 120Hz and other than that it using it for programming / testing programs.
Here is the build, prices from overclockers.co.uk and will most likely be ordering from there.
Intel i7 2700K
Kingston HyperX Beast 2 x 8Gb @ 2400Mhz
Asus Maximus V Formula Z77
2 x MSI HD7970 Lightning boosted edition
Seasonic X-Series 1050W PSU
Asus Xonar Essence ST
BitFenix Shinobi XL full tower
Corsair Hydro H100i
Western Digital VelociRaptor 1TB
2 x Samsung 840 Basic 120GB SSD's
6 x Corsair SP120 fans (to replace rest in case)
IC Diamond 24-Carat thermal compound
3 x NZXT Sleeved sata cables
Just want to make sure this is all compatible
Also would I be able to use this with the Seasonic Power Supply or does it really need to be the AX1200
Also on the description of the motherboard, it says it has 2 CPU fan connectors, 3 Chassis connectors and 3 optional connectors, is there a difference between the chassis and the optional connectors?
Also I might not be willing to change my mind to a lot of the suggestions if all this works well together even though there are setups out there that would be bit better.
Total comes to £2400, but it can go up by an extra £200 or so
Thankyou!
Intel i7 2700K
Corsair Hydro H100i
Thankyou!
