AlienALX
Well-known member
After having the 5820k for two years I finally decided to look into upgrades properly yesterday. I considered Ryzen, and put a bundle together on Amazon. The only small problem with Ryzen is you really need fast ram which I did not already have. And with ram prices as they are it ended up making the bundle expensive. The total price for a Ryzen 1700, B350 Strix and 16gb Corsair Vengeance 3000 (just using that as an example, Gskill is more) was £517 and some change.
So I started looking around for other options. 5960x is making over £500, so that really wasn't an option. Knowing my luck I would get an early one that could not run above stock on my cooler (120mm aio). Then I found a ten core Xeon that really got me thinking. It was only £230, but the clock speed was awful. Something stupid like 2.2ghz. I looked an Cinebench scores and it was worse than the Ryzen 1700. Back to the drawing board.
So then I found an 18 core E7 Xeon for around £400 or so. Awesome I thought. Then I realised it did not work in any desktop boards. So I looked for a workstation board, but the only boards that were coming up were 4 sockets and cost more than my house.
I went to bed frustrated. I had spent about six hours researching. Then in bed I realised that the newer Broadwell EP chips that released in Jan 2016 may work in my existing board. So I got out of bed around 10pm and came back to the PC so I could check compatibility. I found a Xeon E5 2680 V4 (Broadwell EP) with 14 cores and 28 threads for £369. I then went and checked out a few motherboards, starting with the X99 SOC champion from Gigabyte for £160. It worked.. However, the board is black and orange and orange and blue makes me think of mould. Eventually I found an MSI X99 Plus that again supported the CPU, but this time I found it cheap. £117 "like new" on Amazon Warehouse.
So I pulled the trigger on both.
Here is the Cinebench 11.5 score for a 5960x @ 5.1ghz
And the CPU I bought, which is 120w
I ran it on my stock 5820k and scored 12 lol.
From what I can work out in Cinebench it scores over 2000 points.
* what's weird is that I already have a E5 2680 ! but mine is a V2. But yeah, thought that was kinda freaky.
