Hi everyone,
I have built my PC 6 days ago and it consists of : G-Skill Sniper 8GB DDR3 (dual channel) 1600MHz 1.25volts, i3 3220, MSI Z77A G-45, HD 7870 Tahiti LE etc...
So, it was all working perfectly for a good 3-4 days. Then my problems started. The PC would not boot, and out of the 4 leds on top of the motherboard, only 1 will light up when PC is turned on. So, after reading about my issue, I have found a video on youtube of a guy fixing this problem by taking out the ram and putting it back in. I went ahead and done that, it worked ! YAY . BUT, the next morning, same thing... Tried the same thing, it wouldn't work. So I call my friend and he gives me possible solutions to the problem. Tried all, none worked. So he comes round mine with his rig and a spare monitor to see what the problem is.
We replace his RAM with my RAM and here we go, works, YAY ! It looked like the motherboard was trying to make my Snipers run at 1.5volts instead of their stock voltage. My friends RAM (1.5volts) seemed to have fixed the problem. We went into the BIOS and setup everything for my RAM, put the voltage to 1.25volts, put my ram in, BOOM IT WORKS xP
LED's shining bright like diamonds, playing some COD4 etc. All happy about everything being fixed.
So... today I wake up trying to go on my computer and the same exact thing happens... No video is displayed on the monitor, only 1 LED on mobo lights up. Looks to me like the motherboard tried to force my RAM to run at higher volts again which caused the exact same problem. I don't know what to do now. Even though we have set everything in the BIOS, it just happened again.
I'm very frustrated and I don't know what to do... Should I replace my ram to RAM that will run at 1.5volts or should I update the BIOS while my friend's RAM is in ( like it says on the internet ) ??
I've only built the PC 6 days ago and I'm rapidly getting into PC's xPP
So help me maybe ?
Thanks in advance :')
So help me maybe ?
