Sneak Peek- New Geil memory
Raymo1
Banned
GeIL USA, Inc. announced the new “Esoteria Series”. Esoteria, or
Esoteric, means specialized or advanced in nature, available only
to a narrow circle of people that are highly knowledgeable. Like the
name suggests, this Series of memory is specialized in nature,
designed with the enthusiasts in mind. Racing-inspired, the Esoteria
Series is screaming for speed while boasting real carbon-fiber
integrated onto the heat-spreaders. The carbon fiber is made by
renowned aftermarket BMW Tuner-Vorsteiner with dry vacuumed
form inspired by F1 racing technology. This is no wannabe imitation
of fake carbon fiber. Each of the Esoteria carbon fiber heat-spreader
requires being hand crafted for proper fit. GeIL didn’t just stop at the
looks. After all, it is what’s under the hood that counts. Optimized SPD
to couple with the high-grade chips used in the Esoteria, overclockability
has been increased while retaining stability. Due to the advanced and
complexity nature of this product, it will be shipped in limited quantities.
ESOTERIA SERIES
∗ Available in DDR2 PC2-6400 800MHz & DDR2 PC2-8500 1066MHz
∗ Capacity of 2GB Dual Channel (2x1GB)
∗ CAS 4-4-4-12
∗ Optimized SPD for overclocking
∗ Voltage 2.1V – 2.5V
∗ Black or Silver true carbon-fiber with Heat-spreader
∗ Black or Silver aluminum base heat-spreaders
∗ GeIL Limited Lifetime Warranty
I also have heard from a very good soarce that DDR2 1300 is coming soon with limited quantities from Geil with Very low cas settings
I heard 3-3-3-12 on 1 tick:worship:
Moved to appropriate area of the forum. Raymo, do you by any chance work for, or are endorsed by Geil? The reason I'm asking is that you appear to plug them wherever you can. ;)
Can we pls not continue talking about this please until we have Admin's blessing. Posts have been edited accordingly. If it happens again posts will be deleted
I am not advertising this product, The title of this forum is sneek peeks...
That's what Im doing....
Sorry
I wont do it anymore:(
Sorry
I haven't edited any of your original post. What I did edit was what you put under under your other posts. You must realise that OC3D has contractual obligations or agreements with resellers and manufacturers, and the edited parts of your posts could actually jeopardise them.
name='Kempez' said:
I don't see a problem speaking about RAM if you like it, as long as it's not actually advertising etc.
Exactly, same here. The posts were edited because they eluded to a competition and advertising. Which I spoke to Raymo1 about in his post in the 'introductions thread'.
