Small gaming computer
sg12004
ok i plan on going to insomnia i49 lan event so i will be traviling by train
and dont wont to take my big desktop computer so i am going to build
a mini itx build for the event mostlay playing TF2 dont need to be that powerfull computer
so this is what i have come up with
CoolerMaster Elite 120 Gaming Black ITX Case
http://www.cclonline.com/product/84...sis-with-Aluminum-Front-Panel-Black-/CAS0641/
Asus P8H61-I Intel Socket 1155 Motherboard
http://www.cclonline.com/product/55...Asus-P8H61-I-Socket-1155-Motherboard/MBD0124/
Intel Core i3-3220 3.30GHz (Ivy Bridge) Socket LGA1155 Processor
http://www.aria.co.uk/SuperSpecials...t+LGA1155+Processor+-+Retail+?productId=52002
PALIT GeForce GT 630 2048MB GDDR3 PCI-Express Graphics Card + 1 FREE GAME!
http://www.aria.co.uk/SuperSpecials...Graphics+Card+++1+FREE+GAME!+?productId=54977
4GB (2x2GB) Corsair Vengeance Jet Black Low Profile 1600MHz
http://www.aria.co.uk/Products/Comp...annel+Kit+[CML4GX3M2A1600C9]+?productId=52694
430W Corsair Builder Series CX430M 80PLUS Bronze Modular Power Supply
http://http://www.aria.co.uk/Produc...+Bronze+Modular+Power+Supply+?productId=53654
hard drive i alredy have
what do you guy's think of this small gaming lan computer
got to be mini itx
my budget is £320 max
it's funny that they give you AC3 with that card, it will never run properly.
i guess it will do for TF2, but from a value for money perspective i think you maybe should go with a 650ti boost or smth like that. i take you won't trash that thing after i49.
I personally would go for a A8-6600k (£82.79),a 6670 (38.99) and a Gigabyte GA-F2A85XM (£60). Its a great combo that runs team fortress really well thanks to the 6670 crossfiring with the apu.
after i49 it will be used as a media center computer that graphics card is way out of budget £40 max
was looking at thos componintes aswell exept that motherboard it got to be a mini itx dont have a lot of room in my suit case to put a matx size case
so the mother board with that would have to be
MSI FM2-A75IA-E53 AMD A75 (Socket FM2) Mini-ITX Motherboard
http://www.aria.co.uk/SuperSpecials...et+FM2)+Mini-ITX+Motherboard+?productId=56205
so whould that be ok with that more than the intel build
AMD (Richland) A8-6600K 3.90GHz (4.20GHz Turbo) Socket FM2 Quad-Core
XFX Radeon HD 6670 2GB GDDR3 Graphics Card
I think it'll be a solid build :D. I'm not very knowledgable with motherboards but that 'board does seem to tick all the boxes you want it to, it might make sense to go for faster ram, such as this though as the apus work better with high speed ram.
ok thanks evry one for the advice have decided to go with this
