Guys, need a bit of help on the behaviour of DFI mobos ..
I have my first DFI Ultra-D and an AMD X2 and after the initial windows splash screen comes up I get a "Windows is starting up" screen which it sits at for a long time. I checked the system event log and the TCPIP driver is taking 75 seconds to load which is probably the problem.
The mobo has two network connections: a Marvel and an NVidia and using either gives me the same problem. Also it's the same if I disable the Marvel in BIOS or if I change the adapter properties to 100 full duplex or auto. I have never experienced such a slow windows startup before and none of my other PCs behaved this way and the network has not changed to my knowledge. Is this a DFI thing perhaps?
Any ideas or opinions?
