dhoom New member Feb 12, 2014 #1 Can i put a ASUS GTX780-3GD5 (3 GB ) in SLI with a ASUS GTX780-DC2OC-3GD5 (3 GB )
Kaapstad Active member Feb 13, 2014 #2 You can but you would be better off using two reference 780s as the non reference cards can dump a lot of heat into your case.
Dicehunter Resident Newb Feb 13, 2014 #3 Kaapstad said: You can but you would be better off using two reference 780s as the non reference cards can dump a lot of heat into your case. Click to expand... +1 Plus they look better IMO I mean, Come on, This card is a sexy beast, The DCUII just isn't and as Kaapstad said it dumps a lot of the heat inside your case - Last edited: Feb 13, 2014
