thehidecheck
I spent hours combing through sites to get this the best deal possible... but I still prolly wont buy it atm. I figure I'll share my work anyway.
http://imgur.com/sD5v2,ucsuw,gPJr5#0(all products except cpu on this link)
http://imgur.com/sD5v2,ucsuw,gPJr5#1(total of above-rebates)
http://imgur.com/sD5v2,ucsuw,gPJr5#2(cpu(cheapest in the us))
That totals to $751.58-85(in rebates and gift cards)=$666.58 or 409.75pounds for the chaps(titter titter) across the pond. Chuffing good value if I do say so myself. Slap 2 660ti's as soon as they come out($250 each) or even 2 670's($400) and we have ourselves a beast.(so your prolly looking at $1166.58 total)
Might aswell cover some of my intentions in the build too. This is a strickly gaming build, all bout dat fps. Tried to keep USB 3.0 on the front panel, though cutting that out should shave another 10$ off the build. The 60gb ssd is intended for intel SRT. Only got a hyper 212+ to cool the 3570k but i figure, although it runs significantly hotter, it still dissipates less heat then SB so an expensive cooler isn't actually needed.
Discuss, critique, admire, copy, do as you will.
(arg, linking photos is confusing and oc3d didnt like imgur, I even formatted them abit so it'd fit in attatchments but then they were all shrunk T.T)
