Skyrim freezes ( as does the entire pc and sound )
tharionos
anyone got a clue what might have caused it ?
i never had problems before ( 2 or 3 times 3 hours played easily )
now suddenly the game got stuck so did the pc and the sound had to force reboot
it can't be heat related can it ? i mean it ran skyrim perfectly before and also got stress tested in the store to check for component faillure
also it doesen't have had issues with battlefield as far as i know
now ime worried
i asked the store but the only thing he said was it might be a component overheating whilst last time they said evry component was fine , but he replied that its not compairable to playing games
that has to be wrong now ? , if it does fine during a benchmark or stresstest then surely a game won't make it overheat ?
Not sure if it will fix it but it has proven to be sucessful:
  1. In Windows 7, go to Control Panel > Hardware and Sound > Sound
  2. You will see your default sound device. Click it, then click properties.
  3. Go to the Advanced Tab, make sure the default format is set to 44.1Khz 16-bit.
  4. Hit Apply/OK, then run Skyrim.
asus rampage lga 2011
asus ati radeon 7970 3gb
hd soundblaster pci express
intel lga 2011 I7 12 hexacore
corsair dominator quad channel 16 gb
ps : thx alot for the replies guys , very much apreciated !
does your fix also apply for seperate soundcards ?
Does your steam run in compatibility mode? if yes this may be a fix for you.
  1. Hit start->run->regedit
  2. Go to key: HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
  3. Look for a entry with your path to steam.exe
  4. Delete that entry
  5. If you dont find it there try HKEY_LOCAL_MACHINE\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers
I had similar problem with skyrim and after this everything working fine.
Yeah check that, and check any oc you got. Cpu/Gfx/Ram.
Just cos an oc works in one game, doesn't necessarily mean it's ok in another.
nope , cause i wanted to make sure the game doesen't crash
, before i install anything extra
