hi all
looking to put some water on my 260 but not sure which way to go.
currently i have a XSPC RS360 on my q6600 at 3.3 ghz with an XSPC Delta V3 and a XSPC X2O 400 Pump, i also have a XSPC RS120 that i will be adding to the loop when i get it done.
so what would you suggest to cool my gpu to go with that lot?
if i went with a Razor GTX260 would that be all i need or would i need a ram backplate as well, this is where i am getting a little confused.
also would there be anything i could put on it that would be able to move on to any new gpu i get, as the Razor GTX260 would be only suitable to use with the 260
cheers shorts
cheers shorts
