So I'm attempting to build my first watercooled machine and I need some advice and knowledge from the guru's that know this kind of stuff.
Before I get into any of the specification I want to explain my goal: minimal noise! This will be my utmost priority and the whole purpose of the watercooling (having a noisy machine next to me on my desk will give me a mental breakdown). I will be using the TJ08-E case and installing two radiators: one 180mm in the front and one 120mm in the back. Both will be 35mm or so thick so thin radiators! Also, I will only be using one set of fans on each rad, no push-pull full stop! I will be cooling an i3 2120 and a GTX 560 Ti or GTX 570. But I do not intend on overclocking the GPU so take that into consideration and the i3 is pretty self-explanatory. Should this be able to cool these components sufficiently and quietly?
I haven't quite worked out the rule of thumb yet, but is radiator ability measured by the full area (square/rectangle) or by the circular area that's covered by the fans? If by circular area, this setup should work similarly to a 360mm rad, and if it's full area, it would be much more so. Please correct me though if I've got that all incomprehensibly wrong! =D
Also, I plan to run all fans on as low as reasonably achievable to keep as quiet as possible. I thought Noctua's would be a no-brainer but I've heard they perform surprisingly loud when in a radiator scenario. If this is wrong, again do correct me, and if I'm right could you please recommend good, quiet 120/180mm fans.
Thanks
- Jonathan
Thanks
- Jonathan
