T tigger New member Nov 28, 2015 #1 How does one fix the new window onto the panel after cutting the panel.
dalewakelin New member Nov 28, 2015 #2 3M tape is the easiest and most popular way but you could also drill holes and bolt it on if that is the look you are going for.
Pogal_31 New member Nov 28, 2015 #3 http://www.amazon.co.uk/3M-Double-Acrylic-Mounting-Thickness/dp/B016LCTY66/ref=sr_1_3?ie=UTF8&qid=1448749667&sr=8-3&keywords=double+sided+tape
