goldenchessboard
im getting a custom comp, but should I build it myself or pay some guy at the store to do it? its obviously my first time.. is it too hard/risky to put it together on my own if i've never done it before?
name='llwyd' said:you have to learn at some point
as long as you stick to the obvious guidelines, any problems that occur should just be down to bad luck
be sure to have access to the internet while building though in case things are not in working order once the build is complete
name='goldenchessboard' said:even if the guy at the store does it free? hmm ok. but what if I mess something up and burn out a piece.. do most warrenties cover that?
and are there any intructions that come with the pieces, or is it just common sense?
name='llwyd' said:all yes
and you said in the first post "or pay some guy at the store to do it?"
name='Mullet' said:Well....in my experience....with PCs and other things life may throw at you. If you have the motherboard manual and access to a forum such as this I'd deffo do it yourself!! That way you know it's being done the right way!!
I've bought 1 pre-built system...cost mne a few £s too.
It's very satisfying when the machine boots up for the first time....and it's all your own work!
name='mrapoc' said:Im the same as pat - im 16 and this time last year i was in the same boat as you. Got more confident by askin questions, took my time and it all came out well and still going strong![]()
