Has anyone seen anything like a Sharkbite T fitting that will work on our soft tubing in our PC's. It would be a great way to add a drain valve without a lot of fuss.
You won't get a push fit fitting for soft tube mate, it won't stay in, due to it being flexible,
with the ones I posted you just add whatever fitting you want to each thread.
You mean like this? I don't see anything special about the sharkbite system other than they have been dicks and made their own clamping system and proprietary tools rather than just using pliers or an allen key :huh:
