Sesto Elemento (Sixth Element)
Quick update*
GPU has been fitted and looking really sharp!
I love the stainless steel and black together.
Updates
getting finishing touches done, while waiting for the reservoir to re-seal (Still not happy with it, but it'll have to do)
Changed the white on teh shroud to orange, added a top rght corner with aorus logo (i'll probably change that later to black and orange).
Waiting for a few more things to arrive (RAM) and then i should be good to release final photo's, video and most importantly, results of the tests.
The RAM is here! And by god is it pretty!
Fits this project perfectly, also look at how close the tube run is!
I had to adjust the height of the top run to squeeze in the RAM, but it's in now and working :D
Specs: 2x8GB DDR4 @3000mhz
Team Group T-Force NightHawk RGB White
Sooo.... We ran into complications with the custom res and bubble cooling.
While it works 100% well with the CPU only, it really didn't like the 1080Ti included.
In fact, the reservoir split in the bottom after 4 hours of stress testing.
So i had to quickly re-think some things to get this project done as fast as possible.
While the idea for bubble cooling may be a bust, the design idea is still in play.
From Alphacool
The Eisbecher Lite 250mm reservoir
I'm using Mayhems pastel orange coolant for this
The NexXxoS XT45 420MM Radiator
And those fittings you see are the Alphacool Eiszapfen angled adaptor 90° rotatable
I changed out the legs to something much much better and more fitting.
But i'll reveal them later this week with the finished build.
Some final photo's before it travels oversea's
(I do realise now after taking photo's that the M.2 was not screwed in lol)
Will take more after show and have someone take some during the show :)
Nicely done sir, take a bow. I'm rather impressed and need to see more builds using Orange, love the use of stand offs for creating air flow.
Yeah, orange is very under rated, very vibrant :)
want to add 2 more photo's with different lighting
Outstanding build. Love the cascade reservoir mod. Bitspower are doing this too now.
However, your logo shield is a "little" bit of an eye sore for me. I would have love to see the window without that.
I agree. Could have gotten around it by scuffing or frosting, instead of painting/decaling... I find it just pulls the eye away from what should be the focus. Just my 2 pence.
Otherwise, the kind of build that i wish i had the skills to do. Mad props.
