Server tower to gaming rig
current specs
Dont have clue who made the server case ( but weighs a ton and is very limited for cable managment )
AMD FX 6100 currently overclocked to 4.1ghz ( currently limited by air cooler)
ASUS gtx 550 ti graphics card
8GB exceleram rippler sandy bridge series (overclocked)
ASUS m5a97 Mobo
cheap cpu cooling fan
arctic cooling 120mm fans
cheap tv card
OCZ 500W mod x stream pro modular
uv kit
1.5TB sata 2 mdt hard drive
planned additions soon to come
sabertooth 990fx mobo
custom H100 watr cooling install or dual 5.25 reservoir and pump setup
1 PNY 240gb SSD
Further 8GB excelram
how it all began
found a server case lying around my house must have been one i bought along time ago and never used back then it looked good now it looked abit plain. the tall silver and black one
Decided that i couldnt live with sutch a plain eye sore at the time and thought a temporary respray was in order.
cut the side panel to fit a window in, and accidently dropped my hammer on it so got a nice crack line over it luckily it was only a rough fitting as the panel needs finishing of and smothing over.
next i decided to attack my cable managment and try and work out where i wanted cables to go and how i wanted it to all look, so i went out and bought some cheap tacky hole saws and they did exactly what they said on the tin cuts imaginary sheet steel and chocolate fire guards. burnt out 4 bits in 10 seconds to a state of no teeth.
eventually after getting the tin snips out a flannel for the shear sweat of manual labour i managed to cut a round is hole got the cables through and everything tied up and hidden where i wanted it to be.
and at night
once i got everything in place and fitted up it was time to setup the bios the way i wanted it to get a decent overclock on a crappy am2+ cooler im not cheap i just like the uv red of this cooler until i put the h100 or custom water kit in.
managed to get the ram to decent profile for what it is and windows agreed 7.7 score on windows BS for memory aint to shabby in my eyes.
have got some more work to do and then to get it all ripped back out to take the case to get propperly sprayed rattle can only work to a certain point.
if any one is interested i have some left over stock from asus couple of posters full wall size that are sat in my workshop doing nowt
also got a 2u server case and a 4u server case that i no longer use was tempted to do the 4u as a gaming rig project i think a clear top water cooling project case would be sweet. but havent got the time at the moment the server cases are in top pic i can send more if any one is interested.
its currently a slow paced job but going to start ordering some more parts soon for the water cooling setup and some braiding to individually braid each psu wire.
looking into the sidepanel window im not sure what to do with it yet.
and a new colour scheme
IMHO: i do not know what you used to cut the side panel with, but it needs tidying up. those jagged edges do not look good, dude
but the re-spray looks good.
and, while you are re-doing the side panel... cut some holes in the motherboard tray for some cable-tidying
the side panel was rough cut to get an outline of what i wanted and currently its not so going to redesign it, because i dont know who manufatures the case its a nightmare if i need to find a spare side panel.
also got 1 hole for cable managment was going to put 2 in but the chocolate hole saw kit melted
that to do that hole by hand that i have.
there isnt any room really in the back of the case for cable managment roughly about 1/2 inch
just found out my case manafacturer after doing some searching its a casetek c1021
and they donnt make the chassis anymore and there to come by so dont want to screw the side panel up for sure
Make your own side panel, pretty simple.
Very creative. Love the paint job
im not to sure on it myself at the moment, it was the only two rattle cans i had spare at the time
im thinking of respraying it again soon with a gloss white, perlescent blue with the rear inner panel chrome and the top inner pannel chrome. going to purchase a dremel tomorrow and start looking at chrome painting aswell what you guys think
just finished cutting my side panel and getting it near ready for spraying might have cut a tad to close to where the fan goes but there is always a fix for that
just cut 6 new holes today for the power supply and all other wires to go and the case fan holes before the fans sounded to noisy from air flow just nee to find some edge protector for the side panel and the new holes
if you have an auto part shop near--- head down there and pick up some "door edging" it'll run you about 10$ usd and will clean up that jagged edge perfectly!!!
did you use a shotgun to make the 24pin hole???
nah no shotgun lol
used a pair uf tin snips ages ago when a holesaw melted getting used on the case so had to hand cut it need tidying up but going to individualy braid each wire.
