Sempron 2500+ s754 overclocking
winX
ok.. I bought a new mobo FoxxConn/WinFast with current Bios updates (yeay!)
I got the stock AMD Sempron clock from 1440 MHz to 1623.8MHz but I hear it can go faster. now the multiplier is locked @ 7 :mad: , but this is as fast as it'll go. I heard it can get to 2.1 GHz but i may have to change voltage settings (which I CANT do from bios)
I'm running Samsung PC3200 DDR 400 Ram (with heatspreader), and a 350W PSU (Aopen).
I'm not getting too far on the AMD forums: http://forums.amd.com/index.php?showtopic=58365
CPU-Z id #: 43860
Here's current specs from Sandra:
< Processor >
Model: AMD Sempron(tm) Processor 2500+
Speed: 1.62GHz
Model Number: 2500 (estimated)
Performance Rating: PR2436 (estimated)
Cores per Processor: 1 Unit(s)
Threads per Core: 1 Unit(s)
Internal Data Cache: 64kB Synchronous, Write-Back, 2-way set, 64
byte line size
L2 On-board Cache: 256kB ECC Synchronous, Write-Back, 16-way set,
64 byte line size
< Mainboard >
Bus(es): ISA AGP PCI IMB USB i2c/SMBus
MP Support: 1 Processor(s)
MP APIC: Yes
System BIOS: Phoenix Technologies, LTD 6.00 PG
Mainboard: WinFast 760GXK8MB
Total Memory: 511MB DDR-SDRAM
< Chipset 1 >
Model: Foxconn International Inc SiS760 Athlon 64
CPU to PCI Bridge
Front Side Bus Speed: 2x 696MHz (1392MHz data rate)
< Chipset 2 >
Model: Advanced Micro Devices (AMD) Athlon 64 /
Opteron HyperTransport Technology
Configuration
Total Memory: 512MB DDR-SDRAM
Memory Bus Speed: 2x 180MHz (360MHz data rate)
< Processor >
Speed: 1.62GHz
byte line size
64 byte line size
< Mainboard >
MP APIC: Yes
< Chipset 1 >
CPU to PCI Bridge
< Chipset 2 >
Configuration
< Video System >
Monitor/Panel: Plug and Play Monitor
Adapter: RADEON 9200 - Secondary
< MultiMedia Device(s) >
Device: Standard Game Port
Device: CMI8738/C3DX PCI Audio Device
< Printers and Faxes >
Model: Canon PIXMA iP3000
< Power Management >
AC Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP/2002 Professional (Win32
x86) 5.01.2600 (Service Pack 2)
< Network Services >
Adapter: SiS 900-Based PCI Fast Ethernet Adapter
<< System BIOS >>
< General Information >
Manufacturer: Phoenix Technologies, LTD
Version: 6.00 PG
Plug & Play Version: 1.00
SMBIOS/DMI Version: 2.20
(EE)PROM Size: 512kB
< General Capabilities >
Can be Updated/Flashed: Yes
Can be Shadowed: Yes
Is Socketed: Yes
Supports Plug & Play: Yes
Supports ESCD: Yes
Supports Enhanced Disk Drive: Yes
NEC PC-98 Spec Compatible: No
< Power Management Features >
Supports APM: Yes
Supports ACPI: Yes
Supports Smart Battery: No
< Boot Features >
Supports Selective Booting: Yes
Supports CD/DVD Boot: Yes
Supports PCMCIA/CardBus Boot: No
Supports LS-120 Boot: Yes
Supports ZIP Boot: Yes
Supports i2o Boot: No
Supports FireWire/1394 Boot: No
AGP Capabilities >
Version: 3.01
Command Queue Length: 32
Fast-Writes Support: Yes
Over 4GB Addressing Support: No
Isochronous Mode Support: No
Addressing Support: 32-bit
Data Transfer Modes Support: 4x 8x
< HyperTransport Capabilities >
Slave/Primary Interface: Yes
Version: 1.02
Master Host: No
Default Direction: No
Unit Count: 9
Base UnitID: 0
End of Chain: Yes
Interrupt Discovery & Configur:Yes
<< Video Adapter >>
<< Primary Display Driver (display) >>
< Video Adapter >
Model: RADEON 9200
Chipset: RADEON 9200 AGP (0x5961)
RAMDAC: Internal DAC(400MHz)
Video BIOS: BK-ATI VER008.015.040.000
VGA Compatible: No
Total Memory: 128MB (118MB Video) (54MB System)
Texture Memory: 172MB
Supports DIME Texturing: Yes
< AGP Capabilities >
Version: 3.00
Command Queue Length: 256
Fast-Writes Enabled: No
Isochronous Mode Enabled: No
Addressing Enabled: 32-bit
Current Data Transfer Rate: 8x
< Video BIOS >
Version: 4003.101
< Current Video Mode >
Mode: 1152x864 16M+ TrueColour (32-bit)
Current Refresh Rate: 70Hz
Virtual Desktop Size: 1152x864
< Video Driver >
Model: ati2mtag.sys
Version: 6.14.10.6575
Expected Windows Version: 4.00
Video Acceleration: Yes
Screen Saver Active: 9000 minutes(s)
Screen Saver Name: C:\WINDOWS\System32\logon.scr
Low Power Saving Active: No
Power Off Saving Active: No
If you need a full report, please contact me.
Thanks for your help!!!!
just because one semprn goes to 2.1ghz doesnt meant yours will, but we will try ;)
the info we need to know is FSB, and vcore.
have you tried upping the vcore?
take a look at the amd section of the forum and read up on a few of the guides.
and feel free to ask netin :D
Vcore and FSB
Ok.... the FSB is running @ 232 Mhz
I can't adjust the VCORE in Bios.... crappy board?????
It may be that the board doesn't allow you to adjust the VCORE in the BIOS which means: yes it isn't the best overclocking board (well: pretty shite) ever...
If you can do that you will get higher.... :)
the memory statz are thus:
freq: 180.4
FSB:DRAM: CPU/9
CAS# latency: 2.0
RAS# to CAS# delay: 4 clks
RAS# precharge: 2 clks
Tras: 9
Bank cycle: 12
DRAM idle timer: 16 clks
freq: 180.4
FSB:DRAM: CPU/9
CAS# latency: 2.0
Tras: 9
Bank cycle: 12
Download CPU-Z and give us screenies of memory page, front page and motherboard page mate: would be much better :)
Host it here:
http://upload.sysxtreme.com/
and wrap it in
tage :)
Ouch mate... Asus and SiS don't mix in the overclocking world.
DFI and nF4 do though :D Wait, you have a 754 Sempy. Ok... DFI and nF2/3 then :D
