Seeking advice on my first build, £900 budget
Jao
Hello, I've been planning on building a pc for a while and having just finished my exams have decided to do so. As I'm a practically a complete novice I'm trying to seek as much advice as possible. I've laid this out using a template from another forum, hopefully it makes it easier for you
  • Country: United Kingdom
  • Budget: £900 give or take
  • Resolution: 1920/1080p
  • Games / Settings Desire: The plan is to use this instead of a next gen console. Ideally I would like it to play games at better settings than them or at least as good as. (I understand that's somewhat difficult to figure out seeing as they aren't released yet) / Current games i.e. Metro Last Light at ultra at least 30fps (AA turned down) It also needs to last for a good few years (turning down settings is fine) considering i'll be at uni soon and most likely too broke to afford upgrades lol
  • Any other intensive software or special things you do (Frequent video encoding, 3D modeling, etc): Nope
  • Parts that can be reused: None currently using a laptop
  • Do you need an OS?: Yes
  • Do you need peripherals (e.g. monitor, mouse, keyboard, speakers, etc)?: The PC will need to have wireless connectivity as my room's on the 2nd floor and the line on the ground floor , I also have a separate budget of about £150 for a monitor (as a late Birthday Gift) so some suggestions there would be appreciated.
I also plan on having a go at overclocking, free extra performance and all that.
With this information in mind I've come up with this: http://uk.pcpartpicker.com/p/166fr
  • CPU: i5 3570k (£155.99)
  • CPU Cooler: Coolermaster Hyper 212 Evo (£24.10)
  • Motherboard: Gigabyte GA-Z77X-D3H ATX LGA1155 Motherboard (£99.52)
  • Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory (I believe it's low profile) (£52.99)
  • SSD: Samsung 840 Series 120GB 2.5" Solid State Disk (£71.99)
  • HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM (£49.99)
  • GPU: XFX Double D Radeon HD 7950 (Comes with Crysis 3, Bioshock Infinite, Far Cry 3 & Far Cry 3 Blood Dragon) (£218.99)
  • Wireless Adapter: TP-Link TL-WN781ND 802.11b/g/n PCI Wi-Fi Adapter (£8.76)
  • Case: Xigmatek MIDGARD II (Black) ATX Mid Tower Case (£56.83)
  • PSU: SeaSonic 520W 80 PLUS Bronze Certified ATX12V / EPS12V (£64.10)
  • Optical Drive: LG GH24NS95 DVD/CD Writer (£14.99)
  • OS: Microsoft Windows 8 (OEM) (64-bit) (£67.19)
Total: £885.44
I went for Ivy Bridge instead of Haswell, as combined with a Z87 motherboard I was looking at about a £60-70 price increase and from what I've read the increase in performance isn't that extensive especially when considering that I'm going to be overclocking on air and Haswell's heat issues. And went with the 7950 as it came with all those games which i was probably going to buy at some point anyway, and seems to handle the games at the settings I want for a decent price.
So that's my probably flawed thought process behind the choices explained, are there any glaring errors in the parts I've picked?, Anything you would do differently?
Thanks,
Jao
Grab a closed loop water cooler like the H100i if possible so you can have more fun overclocking ;) but if you want air then you've chosen a nice cooler, just get 2xSP120 fans on it and thank me later :p
Also, if you have any plans to crossfire in the future you'll need another PSU.
As for the graphics card, there are 2 different ones, they changed the PCB on the later ones so the voltage is locked and you will not be able to clock it very well if at all so I would definitely not recommend it, then if you stretch your budget to the better 7950's you start to wonder if you should get a GTX 770.
If it is just for gaming then you can consider Sandy Bridge, it's a shame you can't view the for sale section yet as I will be putting up a 2500k and ASUS Maximus iv Gene-z/Gen3 with 8GB mushkin ram.
Anyway, there's my words and seriously consider doing some research on that graphics card, I can't stress enough on not buying it.
To be honest it looks like a perfectly good rig. The things I would look at would be getting a slightly better ssd such as a sandisk extreme or maybe a slightly better 7950 (XFX has a terrible reputation with their customer service). Also you cant really go wrong with any of the ASUS 24" monitors around the £150 mark. I'm not sure which one is the best but there do seem to be quite a few.
