SD Card Reader Driver
Resonance
So today, I tried to put in a sd card and it worked... but when i tried to put it in the second time, it didn't work. I decided to look under device manager and the reader had a yellow triangle and an "!" indicating that there was something wrong, so dumbly, I decided to uninstall and and try to put the sd card back in and thought that windows would automatically pick it up and reinstall the drivers, but it didn't... Anyone know where I can find the drivers?
SPECS RIGHT HERE
V
Right click on it in device manager and select scan for hardware changes, if that doesn't work restarting your PC should fix it.
Still doesn't seem to pick it up, I may have shifted the wires around when I was messing with it.. though I'm not too sure if that's the case. Every time I run scan for hardware changes, it maybe checks in like <1.5secs..
I may give a go at restarting, but I did try to restart earlier and it gave me the signal that there was no boot device and it nearly gave me a heart attack. (RUNNING MY THIRD MUSHKIN SSD, AFTER THE FIRST TWO DIED)
Haha, i may have to guts up.
Check the wires as well, somehow the ones in my Switch came loose from the front panel and the front USBs stopped working.
The accessibility of the sd card wires are so much harder to get to than the usb ones.. haha. it looks like they are intact, but i can't be certain.
Windows Update did it's job. It' working now. Thanks guys
