Screen 2 flicker
I had a similar issue with my old vc I think its just the oc isnt totally stable for output to dual monitors
yes stable on main monitor but its basically not on the second one. It may be some other issue but thats what I found on my old one. But it was a pos no extra power connectors 4670 basically took its only power from the pci-e slot. the flucuation from 400-900 might be some kind of throttling. Not 100% certain there. Just tryin to assist
i appropriate the help. i think it may be my PSU connector. My PSU is a OLD BFG1000w and my GPU is the lightning II which uses 2 8pins and mu PSU was not equipped to handle that. but it worked fine several hours ago which makes no sense.
i will just go ahead and blame Windows
in all honesty i think it might of been afterburner, i changed one of the values in the Afterburner .cfg file (EnableUnofficialOverclocking) from "0" to "1." unfortunatly when doing this i sets my clocks to constant 3d mode to my clocks stay at 990core and 1300memor at 1.299v. my temps are at 50c idle and 72c load so not so bad. when summer comes though i may need to underclock lol
not bad temps at all what gpu are we talking about here btw lol
My 560ti runs warm but quiet lol I can manually turn up the fan (still on quiet speed) and control it better though.
I am thinking it may be the new 11.2 CCC and the afterburner. i dont thing afterburner was equipped to play with 11.2 CCC yet, so i am going to revert back to 10.2. I LOVE 10.2, the most perfect driver. although i did notice a nice performance gain in 11.2.
When i had eyeinfinity when ever i seemed to oc my hd 5850 the two added moniters would flicker only whlie the card was idle if i was to leave a video or game running in the backround it was fine but while the card was in its idle state the screens would of cause you fits they flashed and flickerd so much. I think what the cards idle at aint strong enough to power the three moniters others say it was drivers but i never had problems after i give the card some more juice at idle but thats what i experianced and it may not work for you as its a different card so clocks and wattage are different but just my 2cents
TBH fella if you look flash is the main problem. Thats one of the reasons its not all that yet.
Ive tried loads of configs and loads of settings with ATI cards and they all do it
